pppoe-client
Displays PPPoE client information. Use
this command to view PPPoE statistics derived from access to high-speed data and broadband
networks. PPPoE uses standard encryption, authentication, and compression methods as
specified by the PPPoE protocol. PPPoE enables point-to-points connection to an ISP over
existing Ethernet interface.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
show pppoe-client [configuration|status] {on <DEVICE-NAME>}
Parameters
| pppoe-client |
Displays PPPoE client information (configuration and status) |
| configuration |
Displays detailed PPPoE client configuration |
| status |
Displays detailed PPPoE client status |
| on <DEVICE-NAME> |
The following keywords are common to ‘configuration' and ‘status'
parameters:
- on <DEVICE-NAME>
– Optional. Displays detailed PPPoE client status or configuration on
a specified device
- <DEVICE-NAME> – Specify the name of the AP, wireless
controller, or service platform.
nx9500-6C8809#show pppoe-client configuration
PPPoE Client Configuration:
| Mode : Disabled
| Service Name :
| Auth Type : pap
| Username :
| Password : fJx5O+5duPjaOaPuXmtLDQAAAAAmvgEXcQ1+eUK4ByHK4aRi
| Idle Time : 600
| Keepalive : Disabled
| Local n/w : vlan1
| Static IP : __wing_internal_not_set__
| MTU : 1492
nx9500-6C8809#
